Shaft tolerance for bearing
Hello all,
I have spherical roller bearing bearing with a diameter of 130mm, I want to fabricated a shaft to fit with this bearing. My question is what is a good tolerance range for the fabrication of the shaft?
Thanks in advance
RE: Shaft tolerance for bearing
thanks greg,
Yes 130mm is the OD
