Where to get prebundled HVAC pipe?
Any suggestions on getting a prebundled pipe (3/4", 3/8" copper) with the a shut-off wire (14-2 w/ground) and thermostat wire bundled in?
This would go between the Compressor and Evaporator of a residential central air conditioner.
RE: Where to get prebundled HVAC pipe?
Try TOTALINE - a CARRIER outlet. This will be your one stop shop for all pipes, fittings etc that you may need (including insulation, gas, flaring tools, brazing kit, gauges, charging kit etc)
