Buckled flange after cambering
I have a project in construction where I specified 3/4” of camber for a 44’ long W12x65 beam. The steel fabricator forgot to camber the beam and installed all of the stiffener plates (7 locations along its length). Then they cambered the beam.
They flange buckled locally at one location. A special inspector checked the beam and said that it appeared that they heated it and tried to hammer out the buckle. He said there was still about a 1/2” of deflection at the buckle.
Our thought is to have them replace the beam, but wanted to see if anyone had other thoughts.
Thanks!
Thanks!
RE: Buckled flange after cambering
Certainly you could calculate some kind of a Q factor to represent how much of the flange is still "effective" and then use that in a bending capacity calculation. That should be conservative.
BA
