NX11 - VB code for Message box timer?
We have a bunch of guys who forget to think about saving as they work. Every once in a while if power goes out or NX kicks someone out or something, they will lose everything they did. So my boss was asking if a button could be created that would run a timer and every 20 minutes or so, a message will pop up reminding them to save.
If this can be done, there are some restrictions I would like to add if it is possible.
1) The timer is automatically reset every time they save. So it doesnt pop up the msg box only a couple minutes after they save.
2) The MSG BOX has an OK button to hit to continue working. We dont want an auto save because there are times we go into files and dont save.
3) If the msg box pops up and they are in a meeting, it wont add more every 20 minutes. Just one will stay on the screen.
I can make buttons and such. I just dont have any idea how to write code for something like that. Is this possible?
RE: NX11 - VB code for Message box timer?
Customer Defaults-> gateway-> General-> Part then towards the bottom.
I have ours set for 30 minutes
ironic that mine popped up as I was typing this...
I was excited to see it was already a setting available for us. Unfortunately, it looks like this only does a "Save All" type of save. Is it possible to set the reminder to doing a Save Work Part Only? If not, then I am back to looking for code that will do this.
Often we have one person working on a tool that is broken down into several units. He might be doing something in that tool in one area while others are doing changes to the unit levels in another area of the tool. If someone does a Save All, it overwrites all of the others and causes problems. So now the original modelers/designers will use save all as they work, but once they hand it off and detailers are working on the different units, they are only to use Save Work Part Only.
Your process is very dangerous in native mode. But I mean that you don't have Teamcenter.
In NX12, it's possible to add Password write protection on part file to avoid this kind of problem. Maybe it will help
Didier Psaltopoulos
http://www.psi-cad.fr
The out of the box reminder is not saving anything..it is just a reminder. Nothing more.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
My problem is I need a timer to remind people to save their stuff and the built in timer is a Save All, which would cause problems for us.
NutAce
I hate to contradict you but I just tested the timer. The pop-up asks, "Do you want to save your work now?" and has three buttons on it. "No", "Save All Now" and "Cancel". Though we can fix any problems with people saving over each other, if this was to be popping up, it would likely be having us spending more time fixing save over problems more than working on the job. No way am I going to turn this timer on and tell people "dont touch the middle button". :oP If this built in timer had an option to switch it to Save Work Part Only instead of Save All, it would have been perfect. It doesnt that I see, so i am stuck looking for some code that can do the same thing.
Though I only have 2 users at any given time, We only have 2 NX seats.
Even my 17yr old Daughter ( who works part-time for us) has enough common sense to not hit the save button on that reminder when it pops up.
I'm gonna run it by the boss, but even if he wants to use it, I think I will continue looking for how to write code to do this safer.
10 hour days? I'm on 12+ right now. Tooling is a rollercoaster...
I "think" I have TC Rapid start? When we traded up one of our ADVDES bundles to a AS5051 a bunch of new stuff shows up on my GTAC downloads page now. including a TC and TC rapidstart tab. Though I have no clue as to how to implement it
