Aluminium 6060/ 3,3206/ Al Mg Si 0,5 - thick plate
Hi there,
We have some cooling shells we use with ethanol as a coolant.
Because its thermal conductivity and resistance to corrosion we have selected the Alu 6060 (Aluminium 6060/ 3,3206/ Al Mg Si 0,5)
The problem we are having is finding thick plates (60mm - 2.4inches)
We are based in Germany but we could get it from any place
Does anybody know where to get it?
thanks
regards,
RE: Aluminium 6060/ 3,3206/ Al Mg Si 0,5 - thick plate
drodrig...
Typically I'd say you would have to arrange a special production [mill] 'run' of the 6060-( ) plate with a reputable raw-aluminum producer.
However, I searched 6060 in several of my normal resources and found VERY FEW specifications... all non-US. ALSO, ALL of the specifications [that quickly I found] were for extruded profiles... NO plate what-so-ever.
Now, IF You were specifying 6061... how many tons do You need...?
Regards, Wil Taylor
o Trust - But Verify!
It seems not easy to find
I just need like 1-2 m2 (10-20 square feet) of the plates with 60mm
6060 was chosen because its good thermal conductivity and alcohol corrosion resistance, would the 6061 be good?
cheers,
drodrig...
Your call. Suggestion...
A clue from the past... when many factors collide, and present an analytical or logistical quandary... in this case a material selection VS a fluid environment VS availability... especially for a unique requirement that may be critical{?]... then suggest You get sample materials and do realistic lab TESTING.
CAUTION. IF fluid is flowing and/or subjected to potential air intrusion, or other contaminates... then introduce those elements for a realistic test.
NOTE. Aluminum extruded bars/shapes, under specific circumstances [by a reputable process/vendor], can be friction stir welded together to essentially make a plate. RE AWS D17.3. Aerospace companies are creating monolithic sheet/plate parts this way.
Regards, Wil Taylor
6060 is difficult to find in plate form because it is most commonly used for extrusions.
The closest composition you're going to find in simple plate form is likely 6063- I would investigate sourcing 6063 instead, if it meets your requirements.
I checked the 6063, it is also fine, but also not available in plates 60mm thick
thanks to everybody
Buy thicker bars and mill them?
60mm is not a standard plate thickness available off the shelf.
it should have on the other dimensions at least 300mm. the only option I found is the 6082
MIC 6 cast plate could be an option, you can find thicknesses up to 4". You will take a hit on the thermal conductivity vs 6063 though.
Looks like a nice option, but the thermal conductivity is like 30% lower
thanks
