Using I joist as beam
Has anyone seen a double I joist being used as a beam/header? I have not and believe that this is not allowed by the manufacturer. I was just seeing if anybody ran into and had any guidance on it. I'm likely going to tell the contractor to remove it and replace it.
RE: Using I joist as beam
I wouldn't use it for any significant loading - especially if the beam is side loaded with a hanger. But it is done fairly often, especially around stair openings. The manufacturer should have some typical details for this. See link below for an example.
https://www.techsupport.weyerhaeuser.com/hc/en-us/...
Same as Canpro, never for significant loading but see it often for stair openings.
