ASME Stamp
ASME Stamp
ASME Stamp
hi every body
i was searching about ASME stamp.
how can i find a list about ASME stamp?
for instance we have L stamp which is using for "Lethal Service" or R stamp "repair Stamp" will be used for a vessel that manufactured comply with ASME code and need a hot repair like welding and also U stamp certify that their products, services and quality system comply with the ASME Boiler and Pressure Vessel Code.
is there any more stamp?
RE: ASME Stamp
You can visit asme.org and find the types of code stamps depending on the code of construction. Also, the R Stamp is controlled by the National Board and not ASME.
RE: ASME Stamp
Thanks Metengr
I found it.
Certificates Offered
Power Boilers -Section I
S - Power Boilers
A - Assembly of Power Boilers
E - Electric Boilers
M - Miniature Boiler
PP - Pressure Piping
V - Boiler Pressure Relief Valves
PRT - Parts
Fabrication Heating Boilers- Section IV
H - Heating Boilers/Cast Iron Sectional Heating Boiler
HLW - Lined Potable Water Heaters
HV - Heating Boiler Safety Valves
PRT - Parts
Fabrication Pressure Vessels -Section VIII Division 1
U - Pressure Vessels
UM - Miniature Pressure Vessels
UV - Pressure Vessel Pressure Relief Valves
UD - Pressure Vessel Pressure Relief Devices
PRT - Parts Fabrication
