Surface Flatten
Surface Flatten
Surface Flatten
I am trying to flatten a cylindrical/circular surface, can you help; my flatten option is grayed out on Solidworks 2017. If it's posible for you can you create one so I can use as sample?
RE: Surface Flatten
sg20,
You are not providing us much info. Flattening is a sheet metal process. You have to convert to sheet metal. If you have a tube, you have to rip it to create a seam.
JHG
RE: Surface Flatten
There is a Surface Flatten option in 2017. If you haven't already read the help. If your still having trouble using it, then post more information so we can help you better.
Scott Baugh, CSWP pc2
CAD Systems Manager
Evapar
www.evapar.com
Quote:
"If it's not broke, Don't fix it!"
RE: Surface Flatten
SolidWorks Advanced Surface Flattening is a SolidWorks Premium feature.
http://www.solidworks.com/sw/products/3d-cad/advan...
There are also Sheet Metal features flattening which is in core SolidWorks.
Show us a screen shot of which command you are attempting to use?
Anna Wood
SW2015 SP5, Windows 7 x64
RE: Surface Flatten
That is not a surface, that is part with Mass. Attached is how you flatten a surface.
Since you do not have flat face, you cannot use convert sheet metal on your part. My suggestion, is that you try offsetting a surface @ 0.0, and using the Flatten surface command like I did in the attached file. (Version 2017)
CAD Systems Manager
Evapar
www.evapar.com
