Uf_clone setdef associative file copy
this routine sets a logical in the current clone operation indicating whether associated files should by default be copied (for a clone), exported or imported in the current operation
Hi
Can someone please explain what this mean.
If for example i clone import an Assembly that contain components
that have non master drawings (specification part type)
Do this mean that if the master is cloned then also the
Non master will be cloned.
Thank you in advanced.
Hi
RE: Uf_clone setdef associative file copy
