What should I use for welding material CAST IRON. EN-GJS-400-15.
What electrode should I use for welding material CAST IRON. EN-GJS-400-15.?
Thank you for teaching.
RE: What should I use for welding material CAST IRON. EN-GJS-400-15.
Cast iron welding rods perhaps
Lots of info on welding ductile iron on the web. We have a local foundry that routinely welds their DI, using 308 filler wire. They tightly control their iron chemistry so I can't tell you how they do it. Most sources say using high Ni content rods and some preheat will help prevent cracking.
This is one place to start: https://www.ductile.org/didata/Section8/8intro.htm
