Help needed: terminate job
How can I terminate my job that is run in parallel? My job could not be deleted through command and looks like I cannot do anything through task manager as well. When I check abaqus licensing, sometimes there are 30 licenses and sometimes 8 licenses in parallel, and the model is still running from many days. But I want to delete it and remove the licenses in parallel. I tried to solve it but I am new to abaqus and I am not being able to figure out the exact issue. Any help would be highly appreciated.
Thanks.
Thanks.
RE: Help needed: terminate job
Thank you. Is standard.exe the file to be deleted to kill the job?
The command, that has to be executed in the work directory of the job would be:
abaqus job=jobname terminate
https://welsim.com
