NX9 Clearance Browser off screen for multiple monitor setup
I use my laptop with multiple docks and monitor setups. Recently, the display of the Clearance Browser has moved off screen. Does anyone know how to reset the location of the Clearance Browser so that I can once again see the results of the Clearance Analysis?
RE: NX9 Clearance Browser off screen for multiple monitor setup
I had the same issue.
What I always do is use the Windows key and arrows to move the menu to the correct monitor. Sometimes it remembers this new position, sometimes it doesn't.
If this doesn't work for you,
You can reset your Window position. using User Interface Preferences.
But this will reset ALL windows positions of course.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Hey NutAce...thanks for the reply!
Got things straightened around using a slightly different approach.
The display problem I was having was caused by indicating a different "Main" monitor between various setups.
Setting the "main" monitor to my laptop for every other monitor configuration solved the issue.
Lesson learned: Don't set your "main" display to a monitor that may not exist in other setups!
