Remove Leading Zeroes in Parameter (Knowledge Reaction)
It's the end of the day, and my eyes are exhausted. Just need someone to push me through this one...
I've got a KBE reaction that fires a VB action to convert a parameter to a string, and shortens it to two decimal places. The only problem is, I need to also remove the leading zero, IF the number is less than one.
Clearly, I need another line of code in there to analyze everything to the left of the decimal point. I know this is easy, but I'm just too tired to see it. Your help is appreciated.
CODE
Dim inPart as Part
Set inPart = GetPart(parameter)
Dim retThickness As Double
retThickness = inPart.Parameters.GetItem("Thickness").Value / 25.4
retThickness = Round(retThickness, 5)
Dim strThickness As String
If InStr(retThickness, ".") > 0 Then
If Len(Right(retThickness, Len(retThickness) - InStr(retThickness, "."))) >1 Then
strThickness = Left(retThickness, InStr(retThickness, ".") + 2) + 0.01
Else
strThickness = (retThickness)
End If
Else
strThickness = retThickness
End If
If InStr(strThickness, ".") = 0 Then
strThickness = strThickness & ".0"
End If
inPart.Parameters.GetItem("ThicknessStr").Value = strThickness
End Sub
Function GetPart(inElement as Object) as Part
Dim holder As Object
Dim i as Integer
Set holder = inElement.Parent
i = 0
Do While i = 0
If TypeName(holder) = "Part" Then
Set GetPart = holder
Exit Function
ElseIf TypeName(holder) = "Application" Then
Set GetPart = Nothing
Exit Function
End If
Set holder = holder.Parent
Loop
End Function Clearly, I need another line of code in there to analyze everything to the left of the decimal point. I know this is easy, but I'm just too tired to see it. Your help is appreciated.
RE: Remove Leading Zeroes in Parameter (Knowledge Reaction)
