Steel Plate to Plywood Connection on the Vertical Plane
I am attaching a 5" long 1/4" x 2" steel bar to a 1/4" steel plate on vertical plane. What kind of connectors I should use and what I should check ?Any help ?
RE: Steel Plate to Plywood Connection on the Vertical Plane
Your post does not match the title of the thread "Steel Plate to Plywood Connection on the Vertical Plane". Perhaps you should provide a sketch indicating the connection and the forces to be resisted.
BA
