shaft key
shaft key
RE: shaft key
Yes. I agree.
What is the question?
RE: shaft key
Is there any affect of shaft key looseness? any limit or standard? how to solve it?
RE: shaft key
In general, if the key is loose, and you are not restricted from doing so, install it with a dab of Loctite PST, which should prevent it from wobbling around too much without making it impossible to remove.
Mike Halloran
Pembroke Pines, FL, USA
RE: shaft key
Why is it loose?
Does it have excessive side clearance?
Is the key or keyway worn?
RE: shaft key
In larger machines the key is often a pair of tapered keys so that they can be tight.
Loose keys are not good, and they will only get worse.
