Piping Alignment to Pump
Dear All,
I just want to know if it is needed to perform the alignment checking if the pipe connected to the pump suction has a "rubber bellow"? Based on my initial result, the displacement of the flange connected to the pump nozzle at load case WNC+H is reaching 168 mm. It exceeded the allowable displacement set by API RP 686 of 1.5 mm.
Thank you and hope for your reply.
marchie
RE: Piping Alignment to Pump
Yes,
Any attachment to the pump imposes some forces.
I don't fully understand what you mean by 168mm - Do you mean the flange moves that much?? Something very wrong there.
marchieV,
Are you saying one side of the bellows (attached to the pump) does not move whilst the other side of the bellow (away from the pump) moves laterally by 168mm or axially? If so the design is not acceptable unless the rubber bellows is around 10D long. Re-design warranted I think here.
Is there a decimal point missing in '168'?
If it exceeded the API specification, then fix the problem. Don't sign off on an out-of-spec condition.
You should assume the "rubber bellows" is not there for purposes of alignment. The pipe should be anchored adjacent to the bellows.
