NX12 Performance.
NX12 Performance.
Has anyone noticed that NX12 seems to be slower when performing simple tasks? things like using the undo function seems to take more time than it should, even on simple models. I've just had an assembly where I performed a "show only" command on component and NX12 took an age to complete the command. I've noticed that even just opening menus isn't as quick as it used to be in earlier versions.
Cheers
Si
Cheers
Si
Best regards
Simon
NX7.5 NX8.5 NX9 NX10 NX11
NX Consultant
www.team-eng.com
RE: NX12 Performance.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX11 / TC11
Drafting in particular has a number of "grinding" features, to mention a few
Note Label, takes looong time to show that dialog.
"Rapid dimensions " the dialog is not rapid.
In Sketch, ( Modeling and Drafting) editing a automatic dimension such that it becomes a driving dimension,double click, edit value+Enter, no fun.
the worst part is that i don't know what to do about it.
"Enhancement Request : please make the notes label dialog 2 seconds faster." ?
I don't think Siemens will spend much money on that enhancement.
Tomas
Tomas
They are all new parts.
@toost
Yes I fully agree, some of the menu commands are just to slow to be acceptable, not sure what has gone on.
Best regards
Simon
NX Consultant
www.team-eng.com
