NX11 Sheet metal issue
RE: NX11 Sheet metal issue
I tried to replicate but could not.
See attached part.- If this is different built , which makes a difference, - rebuild and repost.
I run NX11.0.2.7
I see that you run the initial release of NX11.
I think you should upgrade to the latest NX11 Maintenance release, = 11.0.2
Tomas
Tomas
Thank you, this confirms that it is an issue and we desperately need to upgrade.
I don't see this issue in NX11.0.0 or NX11.0.2
