Degree of Freedom Ordering of [M] and [K]
I am able to extract the mass and stiffness matrices using the following codes in APDL:
*SMAT, MatK, D, import, full, file.full, stiff
*SMAT, MatM, D, import, full, 2d_beam.full, mass
*export, MatK, mmf, matkMMF.txt
*export, MatM, mmf, matMMMF.txt
I then read them in MATLAB as two full matrices.
The modal analysis results in MATLAB are consistent with those from ANSYS. This proved the correctness of the two matrices.
However, I am wondering how the degrees of freedom are indexed in these two matrices by ANSYS.
From this webpage https://www.sharcnet.ca/Software/Ansys/17.0/en-us/..., I tried to read the Nod2Bcs vector and map with the node numbering in APDL. They don't match.
I also tried this one: http://www.ansystips.com/2017/10/export-stiffness-.... The DOF's do not match as well.
Does anyone have experience in the DOF ordering of these matrices?
RE: Degree of Freedom Ordering of [M] and [K]
How did you determine the DOFs does not match?
Did you use both MapForward & Nod2Bcs?
Kind regards,
Jason
I've figured out the DOF ordering of [M] and [K] using MapForward and Nod2Bcs. Thanks for your tips.
I'm looking for a method to transform them back to the user ordering in MATLAB for other analyses. Do you have any thought on it?
Raymond
Matrix from the .FULL file is in BCS ordering. The index array from MapForward and Nod2Bcs maps in both directions of User Ordering & BCS Ordering.
Perhaps look into SPMWRITE to see if it fit your needs better in Matlab. The matrix is in state-space and allows for simpler DOF identification. From the help:
Kind regards,
Jason
