Problem with cutting on Bystronic 4020
Good day to all. We have a problem with our laser. The first slice of the day is perfect, and then gradually things get worse. With 100% power on screen, the power reaches 2500 watts. Then changing the parameters is not a result. Slice remains the same with any parameters.
RE: Problem with cutting on Bystronic 4020
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
If you ask me to do something, I will do it. There's no need to nag me every 6 months
