creating BOM from ONE part file
For some basic design work, I like to import a part within a part instead of creating a separate assembly file. For example, I am making a simple aluminum block that requires one screw. Instead of designing the block and then creating an assembly file with the block and screw, I simply import the screw part into the block part to check sizing, etc....and done.
Question: this works fine for me except with making a BOM in the drawing. With all the BOM options, I would think there is some way to create a BOM of all the separate BODIES in a part file, since the imported screw comes in as a separate body. The same thing would apply if one does not import a second part, but rather designs a couple of "separate bodies" in one part file (e.g. click off the merge toggle when extruding....etc). It seems these bodies could be made into a BOM.
Anyone have some ideas?
Paul
Paul
RE: creating BOM from ONE part file
Try making your part a weldment.
JHG
Thanks for the tip...I have never used the feature, but will check it out. HELP description speaks if some of the elements I am looking for....so encouraging.
Paul
