rule of thumb when to use monolithic turn-down slab vs slab same thickness
If I have an equipment on skid say 40' long and 15' wide, should I just use 1'-2" thick slab (it's 1'-2" because the grade varies).
Or 6" inside slab thickened at the edge (monolithic turn-down slab).
What is the rule of thumb on this. This is concrete savings vs difficulty of forming.
Weight of equipment is minimal.
RE: rule of thumb when to use monolithic turn-down slab vs slab same thickness
