Relation between Minimum Leak Path and Minimum weld throat for Tube to tubesheet joint
I need to establish a relation between minimum leak path dimension (Section IX) and minimum weld throat (Section VIII Div-1 UW 20) for Tube to tube sheet joint. Does anyone have any literature pertaining to it?
Kunal
Kunal
RE: Relation between Minimum Leak Path and Minimum weld throat for Tube to tubesheet joint
Kunal
