Fastening into End Grain of Laminated Member
I am familiar with NDS §11.5.2 End Grain Factor, Ceg which requires a reduction for screws fastened into the end grain but what if the main member is a laminated section? Can the laminated section be treated as solid section? It would be my assumption that if you are near the joint between two laminations it would be weaker than if you hit in the center of single lamination.
The particular scenario that I am faced with is attaching a glass guardrail to a red oak wood tread. The owner wants to use a 2" thick tread in the configuration shown in the _HOF attachment. I have told him I don't believe this will work but I would like to point to a publication stating as much.
Drew Dudley, P.E.
www.dudleyengineering.com
RE: Fastening into End Grain of Laminated Member
In terms of the screw stripping, it will be stronger if the screw bisects the/a glue joint. The glue joint will improve the long fiber resistance to stripping by a small amount, actually increasing the circumferential area of the fibers which will need to be sheared for stripping. Actually, some epoxy glue in the pilot holes of screw improves their pull-out strength too. I don’t think you get any special credit for the end grain reduction coef. because you are screwing into the end of a GlueLam member, it is still basically the end grain of solid sawn lumber. Longer, larger dia. screws would give improved pull-out values. You could use inserts which have a course outer thread and a machine screw interior thread. They are threaded/driven into a hole in the wood and then a machine screw replaces the wood screw. You could take .75 or 1" round bar stock about 3"- long and tap machine screw holes perpendicular to its long axis and 1.75" apart. Then, you drill a hole for the .75 or 1" round in the underside of the tread, and two clearance holes in the end grain for machine screws. I doubt that any of the above is covered by the NDS, but some fastener suppliers may have some ideas or testing data on some possibilities. Does this embedded standoff detail with screws at 1.75" o/c give a canti. moment which can handle 200# lateral load at the handrail?
Drew Dudley, P.E.
I agree with you about not liking to screw into the end grain, but the wood code does allow it like you said with the reduction factor of 0.75. So I think you are right to just calculate the withdrawal and shear on the screws and find a screw that works. Personally I would pick something long and skinny, I just checked 1/4” x5” embed lag screw and it works, but I didn’t check the edge distances and bolt separation in NDS so don’t forget to check those. Maybe you already use this, but the AWC bolt calculator is one of my favorite websites: http://www.awc.org/codes-standards/calculators-sof...
I have a question for you though - how do you verify the 5/8” glass? Do you have an allowable tensile capacity you use for bending? And any local punching calculation for the screw connections? I’d be worried the glass will break before the screws.
--Luke
Mike McCann, PE, SE (WA)
Mike: The moment is developed in a couple between the standoffs in the treads above and below. The treads are approximately 6 3/4" vertically part which is the moment arm.
Drew Dudley, P.E.
Like Mike, I think you have a problem developing the connection that way. Using the moment arm as the riser dimension doesn't work. Your connections follow the slope of the stair, so each connection has to work on its own.
Drew Dudley, P.E.
I agree with that dimension, and agree with KootK about fastening two panels on the same tread.
