90 deg Conical Head
90 deg Conical Head
Our client has an existing pressure vessel with a 90 deg included angle conical bottom head. It currently has a dimple jacket. They want to remove the dimple jacket and install a convention jacket on the bottom cone. There will be a closure ring at the top and bottom of the jacket cone. Does the 60 deg max angle without a knuckle radius still apply if I do not have a cone to cylinder junction? What design approach should we take with our scenario?
RE: 90 deg Conical Head
I cannot determine the configuration of either from your description.
