Pneumatic Pressure Regulator Valve
Hi all,
I'm looking for a valve that will keep a constant pressure of a set value in the system.
The valve will be connected to an air line that acts as an exhaust to release the pressure to the atmosphere.
Some air low characteristics:
1) Pressure - 0.035 Bar (this is the pressure that the valve needs to maintain)
2) Flow rate - 5-8 L/min
3) Humidity - 90-99%
4) High salinity
I'll attach a schematic drawing of the system for better perspective.
Suggestions will be much appreciated.
Best,
SD
4) High salinity
Best,
SD
RE: Pneumatic Pressure Regulator Valve
So if you have any brand suggestions,that might help.
This is exactly the solution we implemented on the alpha prototype, but it takes up a lot of volume and we need to rexuce the form factor.
This special factory in Germany has solved problems for me many times. Have a look at this product line. I am sure you will also find competitors.
https://www.mankenberg.de/en/20/prgb:2/pr:43/produ...
