Set text color Drafting Macro
Hello all,
I'm trying to set the red color on a text I have added with the following code taken from VBA help:
Property Color( ) As long
Returns or sets the color of the drawing text.
Example:
This example sets the Color type of the MyText drawing text to red
redCol =-16776961 'Encoded RGBA color within long integer (R=255 G=0 B=0 A=255)
MyText.Color = redCol
Code I'm trying:
MyText.SetFontSize 0, 0, 20
redCol = -16776961
MyText.Color = redCol 'ERROR
SetFontSize works perfectly but the line for the colour doesn't...
Another thing I've tried is this code, based on a search I have done in the forum, but doesn't work neither:
MyText.visProperties1.SetRealColor 255, 0, 0, 1
Any ideas?
(I'm coding on VBA)
RE: Set text color Drafting Macro
Hi
CODE --> CATScript
' Purpose: This macro will change the color of all text in drawing to red
' Usage:   1 - Works in an active catdrawing
'          2 - Run macro
' Author: ferdo (Disclaimer: You use this code at your own risk)
Language="VBSCRIPT"
Sub CATMain()
' Set the CATIA popup file alerts to False
' It prevents to stop the macro at each alert during its execution
CATIA.DisplayFileAlerts = False
Set oDrwDocument = CATIA.ActiveDocument
' Retrieve the drawing document's view collection
Set oDrwView = oDrwDocument.Sheets.Item(1).views
Dim drawingDocument1 As Document
Set drawingDocument1 = CATIA.ActiveDocument
Dim selection1 As Selection
Set selection1 = drawingDocument1.Selection
selection1.Search "CATDrwSearch.DrwText.TextString=*,all"
'For each view search text
For i = 2 To oDrwView.Count
'Scan all the Texts of the Views
For numtxt = 1 To oDrwView.Item(i).Texts.Count
Set CurrentView = oDrwView.Item(i)
'Change the color of the text in RED
Set Drwselect = CATIA.ActiveDocument.Selection
Drwselect.Add oDrwView.Item(i).Texts.Item(numtxt)
Drwselect.VisProperties.SetRealColor 255, 0, 0, 0
Next
Next
End Sub
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Thank you for answering but I have the same problem...
What I'm trying to do is put in red only the word I've just written.
Sub InsertText()
Set MyDrawingDoc = CATIA.ActiveDocument
Set MyDrawingSheets = MyDrawingDoc.Sheets
Set MyDrawingSheet = MyDrawingSheets.ActiveSheet
Dim MyDrawingViews As DrawingViews
Set MyDrawingViews = MyDrawingSheet.Views
Dim InsertText As String
InsertText = InputBox("Insert Text")
'Set myText.... As DrawingText - adding texts
Set myText = MyDrawingViews.ActiveView.Texts.Add(InsertText, 33, 75)
myText.SetFontSize 0, 0, 20
myText.VisProperties.SetRealColor 255, 0, 0, 0 'ERROR
End Sub
Or, if you don't want to use search
CODE --> CATScript
Sub CATMain()
           '~ 'Change the color of the text in RED
                           DrwSelect.Add myText
                  DrwSelect.VisProperties.SetRealColor 255, 0, 0, 0
End Sub
Fernando
Great, much better!
I didn't find the way of putting the variable in the following code...
selection1.Search "CATDrwSearch.DrwText.TextString= ____ "
Actually, I have to put a string followed by the variable, anyway... now works perfectly.
Thank you very much Berto.
