I have extracted lines and attempting to extrude them
but NX cannot select them (no matter the filter). If, without any any command selected, they show up as lines or splines (whatever) but will not extrude, divide, revolve, etc. If i preselect it and then select extrude (as an example) it says missing selection string. If i recreate it in this same space i still cannot select it. tried on 2 different systems and NX 8.5 and NX 10 so must be within files
any ideas??????
any ideas??????
Cj Silver
Tooling Engineer
Live everyday like no one is watching...
RE: I have extracted lines and attempting to extrude them
can you export the curves then reimport them
The info window should tell what type etc these objects are.
I would guess that the objects are corrupted - the model they came from corrupted and missing some critical data that NX expects to find.
Try Part Cleanup
try File - Export - Heal Geometry
Tomas
Cj Silver
Tooling Engineer
Tomas
There is a chance the work part was not the assembly that you were working in, and the curves are in a component file.
So when extracting the lines, verify what the work part is so you get what you want.
