Optical sensor
Optical sensor
Hi, I am looking at designing a piece of equipment that will reduce the vibration in a small scale RC Helicopter. For this I am looking to measure the phase of the helicopter and the dc motor I will be using as the shaker. To then ensure the motor is 180 degrees out of phase with the helicopter. The question I have is how will I design a circuit to utilise an optical sensor to collect phase information of the helicopter and then the dc motor? Thank you in advance for your input
RE: Optical sensor
RE: Optical sensor
The following 'Duhhhh lesson learned' is an important element in aircraft vibration...
In the 1980s I worked on several propeller driven Vietnam era aircraft. We were constantly dispositioning repairs for odd/annoying cracks, chafing/galling, etc.
During the examination of one aircraft [OV-10A] for a 'slow climb-rate problem' it became evident that the variable pitch prop-blade pitch settings [for each blade] and blade-tip-tracks were out-of-tolerance. The defective prop assys were replaced and the 'newly overhauled assys' were precision evaluated/re-adjusted for matching-everything: blade pitch, variable pitch synchronization, blade-tip-track and [Duhhhh] dynamic [on-engine] balance.
We also discretely 'sanded'* the top-coat paint finish on the spinners, wings, booms and stabilizers to attain a much smoother appearance... since the paint was noticeably grainy/rough all-over [to the touch]. Although the sanded aircraft looked 'odd' [to say the lest] the results were a much 'smoother' skin surface texture.
[* using jitter-bug sander with fine-weave Scotch-Brite pads and a ‘light-touch by the mechanics’... HOWEVER, we didn’t touch the paint on balanced control surfaces]
The results of this evaluation, adjustments and maintenance actions were like a lightning-bolt hitting us engineers and the maintenance team squarely in the brain!
Critical attention to these static/dynamic elements made for [instantly] one of the 'smoothest-running-fastest-climbing aircraft' in the fleet. It was more than evident that attention to these 'small static/dynamic details' had an amazing effect on the entire aircraft: performance and vibration-wise.
We took this lesson to heart. All fleets of prop aircraft were re-examined in-light-of-these lessons-learned on this one aircraft. The maintainers and flight crews noted a vast reduction in damage/discomfort and an improvement in the quality of ‘everything else’: flight-performance improvements, reduced noise/vibration, diminished structures/systems problems, etc.
Regards, Wil Taylor
o Trust - But Verify!
RE: Optical sensor
RE: Optical sensor
RE: Optical sensor
I also wonder if the simple eccentric spinning around one axis, even if you can get it exactly phased, will be able to counterbalance the helicopter's motion, which may not be a simple planar sinusoid.
Maybe you could fly a recorder and a six-channel accelerometer first, to get a handle on the problem you are facing, before trying to develop an automatic system to compensate for the problem.
Mike Halloran
Pembroke Pines, FL, USA
RE: Optical sensor
TTFN (ta ta for now)
