Dropping Modal results into harmonic
Hi All
I am doing a modal and harmonic analysis
Why aren't the resonance frequencies resulting equal in two cases if I drop the modal solution onto harmonic analysis system and if I don't drop and do the harmonic solution independently from Modal results ?
RE: Dropping Modal results into harmonic
How are you determining the resonant frequencies?
Kind regards,
Jason
By doing a modal Analysis as a stand alone Analysis
