selection pressure gauge after PRV
I have some inquiry regarding the pressure gauge selected range & fittings , for natural gas line size (2 inch) to fit after reducing regulator valve ( downstream ) the pressure will reduce from 16 bar to 3.5 bar , pressure max = 18 bar , min pressure = 1.5 bar , max flow 43.5
Ahmed
RE: selection pressure gauge after PRV
When you ask a question on this or any forum, it's up to you to go back and look for an answer.
Roydm answered your question almost a week ago, on 21 December 2017.
Check out his answer:
[img http://www.eng-tips.com/viewthread.cfm?qid=433625]
thank you alot
