Impact test requirement for SS 304L ( -196°C)
Dear sir,
I have one of the equipment with -196°C and colder temp. (MDMT)with metallurgy of SS304L.
Pls let me know whether Impact test is required at -196°C, If yes then what will be acceptance criteria for test result.
Furthermore confirm whether Lateral expansion is to be tested.
Suyog Gawande
Inspection-MECHANICAL
RE: Impact test requirement for SS 304L ( -196°C)
And what is the Code of Construction???
Dear Gsuyog,
Find out the ASTM code for the MOC. You would get your answer there.
