Air Blower Surge
Air Blower Surge
gentlemen I have one question regarding the air blower surge, a wash air blower and acceleration blower
1- how to determine the blower surging limit ?
2- what is the definition and causes of air blower surging ?
3- how to avoid such condition ?
thank you for the support , waiting your feedback
RE: Air Blower Surge
https://pgjonline.com/2012/04/02/protecting-a-cent...
Ashtree
"Any water can be made potable if you filter it through enough money"
If this blower is surging, it is probably due to either one of the following :
a) There is no min flow FIC / FCV on blower discharge to keep the blower flow at above surge flow when process demand is less than surge flow - remedy : install min flow FIC - FCV. Decreasing blower speed may not be an option here if there isnt much room to do so.
or
b) There is a min flow FIC - FCV on the blower discharge , but it is not acting fast enough, especially when process demand flow decreases steeply. Remedies may include one or some of the following options (i) tune the FIC to enable faster response (ii) change the FCV trim to quick opening (iii) add a volume booster to the FCV to improve opening speed (iv) slow down the rate of decrease in process air demand
