Temperature rating of SA 516 Gr 60
3
Where should I look to find out the minimum temperature rating of SA 516 Gr 60?
RE: Temperature rating of SA 516 Gr 60
Is this an ASME vessel or what?
Yes sir. The ASTM equivalent is A 516 Gr 60
Look at SA-20
r6155
If you mean the lowest permitted temperature that will depend on material thickness and heat treatment in ASME Section VIII, Div 1.
See UCS-66. Look at the curves in the figure therein.
Thankyou All
