Possible reasons for variation in results using a VUMAT and inbuilt model
Hi all,
I have a generic doubt. I have written a VUMAT for Johnson cook plasticity model, it works alright. But, the results are a bit off from the abaqus inbuilt model. Von Mises stress is off by around 100MPa while PEEQ is off by 50%. The VUMAT result is the lower one. I am using the equations used by ABAQUS (as given in the documentation). Can there be any general reason for the variation seen in the results?
RE: Possible reasons for variation in results using a VUMAT and inbuilt model
My recommendation is to run the code independent of Abaqus in a FORTRAN wrapper script that provides the VUMAT everything it expects and see if the results make sense against your calculations. Insert some sanity check blocks in the code.
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
