converting numbers to strings & strings to numbers
I need to know how to convert character strings to numbers and also  how to convert numbers to strings.
Can anyone help?
RE: converting numbers to strings & strings to numbers
Dear Kknowle2
This answer was designed by Mr. Rafael Isassi who wrote this lines:
c     Just write your number to a string, or read your number from a string,
C     instead of to or from an I/O unit (the fortran I/O routines perform the
C     conversion). Example:
C     To convert to a string:
      character*10 string, format
      data format /'(F10.2)'/
      a=3.1416
      write(string,format)a
C     now print your string...
      print *,string
C     To convert a string to a floating point number:
      string='123456.789'
      read(string,*)b
C     now print your number...
      print *,b
      end
I hope this will be useful to you
Here's another example of what KKnowle2 showed you in his reply:
It's in Fortran90/95,  however the Fortran77 code would be almost identical...
(   (10)  and  !  used for comments are not F77 compatible    )
Character(10) string
Real               x, y
x = 53.65                             ! assign an initial value to x, 53.65
Write( string, '(f10.2)' )  x      ! writes 53.65 into the string
Read( string, '(f10.0)' )  y      ! reads the value from string and assigns it to y
End                                     ! note the f10.0 format is nice... you don't have
                                          ! to know in advance where the decimal pt lies.
Dan
