Vertical load and lateral load trunnion lifting lugs
How I can apply lateral load and vertical load to the trunnion lifting lugs . Can I do it using compress software ?
RE: Vertical load and lateral load trunnion lifting lugs
Mike
r6155
DIN 28085 "Lifting lugs for mounting of vessels.... dimensions"
r6155
It is best to use a Compress Nozzle design and set the Pressure SIF to 1.0.
