RISA Vs. Revit Section Shapes
Learning the RISA-Revit link, and I notice that if Revit does not have an equivalent RISA section for a beam/column component (say Aluminum RT8x8x1/4) then it can't replace the component to be changed.
Is there a way to export the RISA section library to load into a Revit component family?
-Mac
RE: RISA Vs. Revit Section Shapes
I don't have Revit on my home computer, so I cannot actually test that the aluminum portion of the mapping works. If it's not working for you, then you should write into RISA support. Most of the same people should be there. Though my guess is that no one will be in their office again until at least Tuesday.
In terms of quickly creating additional families of framing members (cold formed, etc.), it is likely more of an issue with me learning REVIT better.
-Mac
