Floating fastener formula
Guys,
The floating fastener formula from Appendix B of ASME Y14.5-2009 gives only:
H=F+T
This is the simplest case where one part has the same hole size and feature-relating positional tolerance as the other. But what is the general case where the hole sizes and feature-relating positional tolerances are NOT the same?H. Bruce Jackson
ElectroMechanical Product Development
UMD 1984
UCF 1993
RE: Floating fastener formula
I suppose it's H1= F + T1 and H2 = F + T2, but then that assumes the fastener is the same diameter for each portion instead of having a step, so H1 = F1 + T1 and H2 = F2 + T2.
Other than that there's an infinite range of ways to shift tolerance for location from one hole to the other with the projected fixed fastener formula being the limiting case.
If H1=F+T1 and H2=F+T2 then does it follow that:
H1-T1=H2-T2?
H. Bruce Jackson
UMD 1984
UCF 1993
I do not bother with the formulae. This can easily be modelled from first principals.
In the floating fastener case, you have a fastener with a maximum diameter, positioned exactly at nominal. Your holes must not intrude into that diameter. There are multiple solutions to this problem.
In the fixed fastener case. your keep-out is the maximum diameter of your fastener, plus its positional tolerance. Again, there are multiple ways to not intrude into the space.
JHG
Jason C. Wells
