Interpretations of A722
Good morning All - I'm a rookie to the site. If I am in the wrong forum, please redirect me...thanks in advance for your patience!
We supply steel to threaded rod manufacturers. I'm a metallurgist, but am only familiar with machined or forged applications. Two questions:
1. Is deformed bar synonymous with reinforcing bar? Thus, does TABLE 2 Nominal Dimensions for Type II (Deformed) Bars apply to rebar and ALSO to threaded rod? i.e. is cold-rolled threaded rod considered "deformed"?
2. Is TABLE 1 Nominal Dimensions for Type I (Plain) Bars meant to be a definitive list, or just a useful reference for some standard sizes so that the user does not have to perform the calculation for nominal area? One user asserts "you must pick the closest size" although the bar we supply is a diameter that is not listed. We have asserted that the cross-sectional area must be calculated from the actual bar diameter used in the full body test. The distinction is important because it directly affects the calculation of the UTS, YS, and ROA (reduction of area).
Thank you!
Thank you!
RE: Interpretations of A722
www.PeirceEngineering.com
