structural definition
what is the difference between structural design and structural analysis
RE: structural definition
Is this official terminology or just semantics. If you are doing structural design, you probably are doing analysis. Someone else can design something, and you can step in and analyze the thing for structural safety. A structural engineer is a civil engineer who specializes in structures.
JHG
"analysis" is done by analysts focused on the strength/analytical properties of the design.
of course they work very closely together.
Design is what you do to make what you analyzed work.
The original structure was designed. Retrofits and remodels are analyzed, then designed.
Mike McCann, PE, SE (WA)
In analysis we are seeking to understand the theoretical response of structures to applied loads or conditions.
Setting up a beam span with given loads and determining the shears, moments, and deflections of a member. Or modeling a building frame in a computer model and applying loads to it to get the shears, moments, axial forces, etc.
In design we are taking that analysis and finding a solution, or design, that provides a required level of safety or performance.
With a solved model, or hand analysis of a member, determine the required beam size, reinforcing, etc. that would provide a safe structure.
There are also constructibility issues to consider as a designer. The way I think of the difference is the Engineer/analyzer says, "here is what you need to do. You figure out how to do it." And it's the designer's job to figure out how to make it happen keeping all parties happy.
If you are offended by the things I say, imagine the stuff I hold back.
I used to work with a guy who specified aluminium extrusions as his material. Perhaps it would be 1"×2"×1/4" angle. He would specify the extrusion number. The part would be perhaps an inch and a half long for a one-off piece.
JHG
Fixed it for ya!
The SE title is also often used by MEs doing what else - structural design of autos, aircraft, etc. We tend to take the niche a bit more in-depth however, analyzing stress and fatigue to very narrow margins using FEA.
Design. They drew pictures.
Design analysis. They did applied maths on paper.
Structural analysis. They did FEA with computers.
Names stick.
Steve
