Rockfill dam in sea shore
Hi
What are the necessary tests for rockfill with large boulders for sea shore ? i am guessing UCS , micro deval and Los Angeles tests as well as dry density perhaps ?
RE: Rockfill dam in sea shore
stockpile approval (evaluate size, weight, shape, specific gravity) at the quarry and check size again after transportation to the site to check for breakdown in transit
Soundness: check for absorption and run chemical soundness tests as well as wetting-drying test
freeze - thaw test might be necessary depending on your climate
For testing and QA / QC, recommend the following reference which covers the subject well:
U.S. Army Corps of Engineers
EM 1110-2-2302 CONSTRUCTION WITH LARGE STONE
this is available on-line
We have criteria for each of these tests and the rock will comply with these criteria, or be rejected. We'd also do a mine/quarry/pit inspection as there are criteria for the pit too.
Our road and bridge specs are on the internet.
f-d
ípapß gordo ainÆt no madre flaca!
