Long Slots on Double Angle Clip Connection
Is there anything in AISC or IBC forbidding the use of long slots on the back-to-back legs of a double angle connection? I have a simple interior carry beam, fairly lightly loaded (~15 kips end reaction), that I would like to isolate from inadvertently carrying any axial load through the frame columns it is framing between. The beam is carrying a simple point load and there is no floor or deck attached to the beam. I am connecting to a thin column web and the bottom of the carry beam is going to be tapered so a single slotted shear plate with a seat and teflon pad is not a real good option here. In my opinion it would probably be overkill. I am curious to hear your thoughts. Thanks!
RE: Long Slots on Double Angle Clip Connection
