Credible overpressure scenario TEG reboiler
Hello all.
I have always thought it prudent to look at fire case PSV sizing on TEG Dehydrator packages, specifically on the regenerator. I have encountered an instance in which it is being proposed to not consider this case. The issue at hand is the question of whether or not anything other than the TEG itself is present as a pool fire source. Has anyone else run into this?
As far as I am concerned, I think one needs to look at it.
Who is right doesn't matter. What is right is all that matters.
RE: Credible overpressure scenario TEG reboiler
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
