Heat Flux Along a Line
Hello everyone,
So I have a non homegenous wall and i want to trace a line along one surface of that wall and read the heat flux along that line.
I have already created a line. O go to report definitions and i creat a report on the total heat flux alogn that line. But nothing happens, and the report says that the heta flux is 0.
Thank you in advance
RE: Heat Flux Along a Line
Did you create a path on the line and then map results to the path?
Rick Fischer
Principal Engineer
Argonne National Laboratory
