Combining shaft & grade beam resistance
We've got a situation where a possible foundation solution consists of running a large grade beam across the top of two drilled shafts, something like an upside down "U". My question is whether or not we could consider the end bearing of the drilled shafts to be combined with the shallow bearing under the grade beam? We are trying to find a way to resist ridiculously large fixed base column moments combined with very high shear and downforce. Thoughts?
RE: Combining shaft & grade beam resistance
Not very likely -- the stiffness of your strata probably changes enough that one will take up before the other.
Any chance you can batter piles instead?
I thought that grade beamas are designed assuming not soil is beneath them. But, perhaps you can treat it as a wall footing?
