Pneumatic testing (Cryogenic)
Currently working on a LNG piping installation the pipe service is Cryogenic design MDMT is -321F. Materials are SA312-TP316L. Client has requested the completed lines be Pneumatic tested due to moisture concerns. Code is ASME B31.3. Can anyone recommend a minimum metal & test medium (Nitrogen) test temperature.
RE: Pneumatic testing (Cryogenic)
Are you seriously going to pneumatically test pipework based on what someone has told you on the internet ?
Before you pneumatically test anything you should be submitting a testing procedure to your client for review and acceptance.
Look a bit stupid if you put under references - www.eng-tips.com ?
