Create a groove consistent with a milling cutter
I'm trying to model a groove on a curved surface that is to be made on a 5 axis. I only know how to sweep a 2d Sketch which when going around radii smaller than that sketch width causes a clash and cusp error. (see below)
In real life this isn't a problem because we are just cutting away the material, but it would be nice to have the groove modeled as if a circular cutter had been ran around this curve normal to the support surface.
Is there any way to do this in Part Design or GSD?
Any suggestions are appreciated.
https://i.imgur.com/2nU0nKJ.png
https://i.imgur.com/g2SNngP.png
RE: Create a groove consistent with a milling cutter
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
and just move them around to get what you want.
Jenia Ladkov
Harun, Oh that's great, I didn't realise I could get some control lines. Presumably from the "Location Values" tab? It looks like it's only for straight lines through, not a profile.
I'll have a play over the weekend. Thanks,
I use this option when i have very complex curve and I must make surface for spliting.
For example when i making surface for trim cutter, if a can see good you want the same.
