Manufacturing profile shift coefficient
Good day.
I have been looking into tolerancing for gear teeth and AGMA 2002-C16. There is one variable in AGMA 2002-C16 that I do not seem to find. This is the Manufacturing profile shift coefficient that is used to determine the minimum and maximum nominal tooth thickness.
I also know that there might be better ways to determine tooth thickness tolerances if there is someone that is more familiar with these practices, they are also welcome.
