Floor Joist bridging
I live in a house built in 1939. While doing plumbing repairs in the crawl space I noticed the cross bridging between my 2X12 floor joists is not, and has never been nailed to the bottom of the joists. (no nails, holes or splits in the 1X4's)
I understand that, in that era, the rough in guys would nail the tops of the bridging and after the load (rest of the house) was built someone would go back and nail the bottoms. Clearly this was not done.
While under there I noticed a whole lot of my insulation sagging and wanted to replace it. Here is the meat of it...
It would be a lot easier and more effective installing insulation without the cross bridging boards in the way.
Since the bridging has never been connected (78years now), should I just rip it down to make the insulation replacement easier. If its been this long without them connected, do I even need them at all. Surly the twisting and warping is complete by now. I have 1X6 diagonally laid subfloor and then 1/2" original oak hardwoods for all but the bathrooms.
Two of the larger rooms do have some bounce too them, but unbelievably no sagging in those rooms.
Only one small part of the entire 1st floor has some sagging. So a second question for the sagging area is... can I take and beam with shoring under each end in that area and over time take a few turns on it to raise that area back up?
My thought was to rip down the unconnected bridging to make installation of the insulation easier but in the rooms that have bounce nail the cross bridging in place. (if I can even nail into the petrified wood)
I have no idea whats right for the sagging area in a hallway near a bathroom.
Please give me your thoughts on this.
Doug USN retired
Doug USN retired
RE: Floor Joist bridging
A properly sized beam will significantly increase the strength and stiffness of the floor, but I'd be cautious trying to push the joists back to their original shape. Long term deflection in wood can create a permanent deformation.
Most importantly, I'd also suggest that before you replace the insulation be sure to read information on 'conditioned crawl spaces.'
Any thoughts about removing the unconnected bridging to get the insulation upgraded easier and then using strapping instead of putting bridging back in?
Doug
Please remember: we're not all guys!
Remove the never-connected 1x, add insulation, and then straps would be nice.
Old wood may be hard to nail and may be a bit more brittle than you think
